Gas tank fills up slowly...
Old Dec 15, 2010 | 06:25 PM
Mookjong's Avatar
Default Gas tank fills up slowly...
Hi,
I own a 2006 Ford Escape 4wd and when I want to fill the gas tank the gas fills in very slow, very strange problem and when I remove the fuel cap you can hear the pressure release when unscruing the cap.
I have notice that if I drive with the fuel cap removed, nothing out of the ordinary occurs, I was in the assumption that a light should come on or something indicating the gas cap is not srewed properly or something.
I have checked the venting hoses underneet the truck and nothing is out of the ordinary...
Anyone knows what is wrong, or is there supposed to be a metal like door for the gas fillup nozzle that is usualy pushed when filling up gas in the metal gas tank hose that should be there because after I open the gas cap there is nothing in the way. I just wonder if that would ove disconnected and slide down in the fill up hose to tank and stuck in the way down there.
Old Dec 15, 2010 | 08:56 PM
I think you are on the right track. Don't know for sure if it can be removed from the filler neck without removing the tank.
stacie4171
Dec 21, 2012 11:54 AM
awwphooey
Jul 26, 2010 02:47 PM
THEGOOSE
Feb 22, 2009 10:45 PM
odie01
Feb 26, 2008 11:39 PM
DannyC188
Jan 4, 2008 11:05 AM
