Help with an accumulator problem
Old Jun 26, 2022 | 05:20 PM
David rami's Avatar
Default Help with an accumulator problem
does anyone know the name of this valve and where i can get one?
Old Jun 27, 2022 | 02:42 PM
They are called a "schrader fitting".
You need to be careful here because that type fitting was used with older vehicles in the fuel line.
Pretty sure the insert for A/C is different from that used for fuel.
I would be more comfortable obtaining that insert from a dealership parts dept.
You might be able to get what you are looking for at a salvage yard,BUT, must be from A/C system. The tool to remove is definitely different from tire valve stem.
I believe the opening on the tool is different
David rami
Jun 26, 2022 04:52 PM
creativecarpenter
Apr 3, 2022 06:55 PM
rtgiilbert
Jan 19, 2021 05:06 PM
Richard Gonzalez
Dec 5, 2020 03:28 PM
Andrew Fritts
Dec 30, 2019 09:05 AM
