Ignition Switch
Old Jan 28, 2021 | 11:59 AM
Adrian Washington's Avatar
Default Ignition Switch
When i start my 2002 ford escape the starter is still engaged like i am holding the key in the start position, what could that possibly be??? Need advice asap
Old Jan 28, 2021 | 06:05 PM
scott.butler4's Avatar
Does it stop once the engine start?
Old Jan 29, 2021 | 04:54 AM
raski's Avatar
If the key springs back when you release it, I doubt the ignition switch is bad. Two things I would check is a bad bendix on the starter which is not retracting and replacing the starter is the best bet. The solenoid is hanging up and keeping the starter energized.Either case, you need to fix it asap before the teeth on your flywheel are trashed.My money is on the bad bendix gear on the starter.
Dennis Nickerson
Sep 23, 2020 06:08 AM
Boomerang53
Apr 24, 2014 08:53 AM
boomboom1966
Feb 3, 2013 05:37 PM
Rancherodude
Feb 9, 2008 02:14 PM
MJHUGHES
May 16, 2007 08:18 AM
