inlet air temp sensor
Old Oct 30, 2022 | 08:05 PM
  #11
joycie01's Avatar
backprobing wires w/the key in run,(engine off) and found battery voltage on the green wire and not much else on any of the other wires. .05 volts and fluctuating on some of them. maf sensor seems to be working (grams of airflow increasing w/rpm increase); this is on two different maf sensors. no 5 volt reading on any wire. p0113 mil set on second start on both maf's. -40f on iat.
Old Oct 31, 2022 | 05:40 AM
  #12
Can you verify a 5 volt reference voltage present at the throttle position sensor when the key is on ?
Old Oct 31, 2022 | 06:08 AM
  #13
joycie01's Avatar
yessir i will as soon as possible. and report back. thank you for your response.
Old Oct 31, 2022 | 01:39 PM
  #14
joycie01's Avatar
okay, we have 6 wires at the tps; lt. green/blk., yellow, blue/or., brown, dk. green/blk., and yellow/brn. key on, reading thru the loom plug we get 4.86v on the lt. green/blk, 5.05v on the yellow, and 4.38v on the yellow/brn. the others have a negligible reading-.05 or less. of course plug is disconnected from the tps.
td2064
Jul 5, 2017 07:59 PM
blueovalguy
Dec 12, 2009 09:16 PM
danddia
Jun 2, 2008 09:29 PM
yamikidR1
Mar 18, 2008 04:02 PM
roddruiz
Jan 23, 2008 02:04 AM
