moon roof drain
Old Jun 13, 2020 | 09:13 AM
jgs's Avatar
jgs
Default moon roof drain
just acquired 2009 escape xlt- drivers floor soaked after rain-traced it down to moonroof drain- ran weed eater line down to discover the tube is open ended behind dashboard up high above floor. Problem is i cannot find where it connects (possibly just came unattached to fitting?) or if it just needs re-routing to its proper location? i cannot find a diagram anywhere to show me the proper route for the tube.
Old Jun 16, 2020 | 10:36 AM
scott.butler4's Avatar
Your on the right track, I would assume there should be another hose it connects to to empty out under the vehicle, You could take apart the pass side and see how that is set up, should be same side to side.
If there is suppose to be a second hose then you could buy some hose and route it out to under the vehicle so it drains correctly.
James Hitzman
Aug 9, 2019 12:36 PM
stroobydoo
Jul 31, 2019 05:30 AM
F150-07-4.6
Dec 24, 2018 12:07 PM
easyrydr
Apr 17, 2014 09:26 PM
rzrback1992
Mar 24, 2012 06:30 PM
