Noisey Front Brakes 2005 Escape
Old Mar 17, 2013 | 08:23 AM
makuloco2000's Avatar
Default Noisey Front Brakes 2005 Escape
I found this video on youtube, does it seem accurate? Seems to be the most detailed video Ive seen on the web anyway. I was going to attempt to do brakes this weekend.
Old Mar 17, 2013 | 10:05 AM
Brake work is not necessarily complicated, but you should know what you are doing !
Just watching a video is maybe a good start,but there are many things taken for granted that one should be careful when doing brake work. I'm sure we all could find something we would do differently from what we see in the video. Just try to learn as much as you can before getting into what could be a simple procedure with "Replacing pads and/or rotors". Keep in mind you should have the necessary equipment and supplies to consider the job done right.
Old Mar 17, 2013 | 10:47 AM
grindman's Avatar
I would be more concerned with what they didn't show in the video than that because as every one knows that you can run into more problems if you don't know what you're doing. Hanky is right when he said that you must have the right tools and supplies to do the job. The only thing that I say is make sure you have a way of getting to the parts store while you're working on it. and be safe while doing it!
Old Aug 25, 2013 | 08:26 AM
Good stuff thanks!
Old Sep 19, 2013 | 11:12 PM
hope this has helped
makuloco2000
Feb 2, 2014 03:18 PM
MatlockPaul
Aug 29, 2013 09:11 PM
jfed1020
Jul 7, 2012 02:08 PM
sillykidd00
Mar 5, 2012 12:09 PM
Checkedwood
Oct 16, 2009 02:36 PM
