problem no pressure front brake line 06 hybird help
Old Jun 8, 2021 | 08:52 PM
purdum's Avatar
Default problem no pressure front brake line 06 hybird help
Installed and bled right front hose and all is good. Replaced left and while bleeding line (got a couple of good pumps in ) fluid does not move when I open the bleeder. Remove bleeder nothing. disconnect connection to metal line and nothing is coming out when the brake is depressed. I did overfill master while bleeding so I would not run out. I am totally confused. I have removed fluid down to the max line. I did pout the cap on while overfilled as fluid was spilling over top help
Greg
Old Jun 8, 2021 | 09:52 PM
purdum's Avatar
Found it. I guess the line had air. I let it sit open for 20 minutes and it started flowing. the weird thing was the pedal still had pressure (not going to the floor) when it was not flowing. never happier to see brake fluid spilling on to the driveway.
ProStreetDriver
Jun 8, 2018 01:20 PM
Stonegod
Apr 1, 2013 09:48 AM
sbcadillac
Apr 17, 2008 01:59 PM
Double D
Aug 30, 2006 12:21 PM
78ford
Aug 11, 2005 12:02 PM
