video on reinstalling driveshaft. fyi, u dont need a driveshaft to drive the escape
Old Jan 18, 2023 | 11:42 AM
Ton Bon Lon's Avatar
Default video on reinstalling driveshaft. fyi, u dont need a driveshaft to drive the escape
09 ford escape 4wd driveshaft reinstall after driving without it for the summer. experiment to see if fuel efficiency would improve...it did not. i already replaced the u-joints the year b4 and as i was doing that i could still drive the suv without the driveshaft. i thought i was using less gas for the short time the shaft was off so i drove this past summer without it to see if it would be more efficient, it was not or was not noticeable enough to bother doing the job twice a year, once to take and then reinstall.
Old Jan 18, 2023 | 02:14 PM
Folks that do this work all the time are aware to mark the position of the driveshaft in relation to the flange on the differential. WHY ?
When originally assembled ,balance is a consideration and reinstalling the shaft if nothing is changed, hopefully does not invite vibration problems.
Old Jan 18, 2023 | 02:29 PM
the shaft is not balanced on the vehicle so why would the differential need to be referenced to the flange, even though i did do it i would see no need to do it. if i ordered a new complete drive shaft assembly how would one reference it to the diff.
Old Jan 18, 2023 | 05:13 PM
When a vehicle is on a lift and the differential is running ,just because a driveshaft is balanced to itself does not mean it is balanced with the differential..
This is one of the checks done on an assembly line.
ontheroad
Aug 29, 2022 04:06 PM
Sepd114
May 4, 2022 04:47 AM
makuloco2000
Feb 19, 2018 01:29 PM
shoggard3
Jan 21, 2018 12:30 PM
bailey8006
Feb 10, 2010 09:48 AM
