Lost Ignition Key
Old 12-15-2007, 04:54 PM
lambru1's Avatar
Default Lost Ignition Key
Houston! I have a problem, Ignition key is lost, Spare too!
Q. Can a duplicate key be made without pulling ignition switch? VIN #'s, the trick here is the ignition key is also the door key, so if I put in a new switch, then theres still the problem of the door locks. Car. is a 2000 escort,SE nothing special
thanks
Old 12-15-2007, 08:58 PM
Default RE: Lost Ignition Key
Most times M/Y's2000 and forward, the key can be cut by your local dealer by the vehicle VINfrom 'as built' data...
Old 02-01-2010, 01:46 PM
mustangrules's Avatar
Default spare key
this place carkeyexperts.com can make your Ford key and re-key a lock using your VIN number or key code
Old 09-18-2010, 07:10 PM
cbreed's Avatar
Default $320. for Extra Keys ????
NEVER use Walnut Creek FORD in Ca. These people are the worst! Crimnals at best. Sept 18, Quote, "About $60 for the Key fob", Maxine Taylor was RUDE and KNEW Nothing. INV. # 639491 cost $320 for a spare set of keys.
kev
04-16-2013 12:35 PM
lostneedhelp
12-06-2007 11:15 AM
Pastor Wells
07-11-2007 08:46 AM
Pastor Wells
06-30-2007 08:21 PM
scott
09-29-2006 12:43 PM
Quick Reply: Lost Ignition Key
