1999 ZX2 Won't come out of park
Old May 7, 2007 | 10:07 PM
lori5301's Avatar
Default 1999 ZX2 Won't come out of park
We just replaced the alternator and the serpentine belt in my 1999 ZX2. Now the car is locked in park. I can put a screwdriver in to manually release it out of park. It isn't a fuse. Brake lights are both working. Is there any way (other than carrying around a screwdriver) to fix this problem?
Any help would be appreciated.
Thank you in advance. I checked with AutoZone, they tell me I need a Neutral Safety Switch (?) a part that is like $200??? Okay, so I guess I'm looking for a cheap fix.
Old May 8, 2007 | 12:54 AM
mayday's Avatar
Default RE: 1999 ZX2 Won't come out of park
That sounds right. That's about the same price as the one in a friends '04 Maxima I replaced. If you can get a junkyard replacement go for it. The only other choice isa screwdriver. Good news isthe '97 -up Escort/ Tracer sedans and wagons all have the same auto shifter as yours.
Old May 8, 2007 | 06:09 AM
91explorer12323's Avatar
Sorry but cheap fixes are hard to come by these days lol. I just wanted tolet youknow,I had a bone head from auto zone tell me i needed a neutral safety switch one time i replaced it guess what same problem it turned out I had a malfunctioning ignition switch that was some how locking the neutral safety switch.i replaced my ignition switch car was fine took the new neutral safety switch off replaced it with my old one and it still worked the same. Now the only problem with autozone is they will throw them expensive suggestions out there but when it comes time to return that part that did you no good,,well here is the exact phrase you will here sorry but we can not make refunds of any kind on electrical items...Id almost put money on that!! They could be right but the point is if not thats one pricey part to replace if you dont need to..
Old May 9, 2007 | 12:48 PM
wheelsup68's Avatar
Usually you can dismantle the shifter assembly and remove the plastic interlock by bending or breaking it. May sound crude but it is a cheap fix.
MatlockPaul
Oct 12, 2014 08:15 AM
crabride
Apr 17, 2012 04:51 PM
buckjv
Feb 3, 2011 07:00 PM
hittecheg
Jan 7, 2009 05:07 AM
rlevy64614
Sep 25, 2008 09:13 PM
