brake safety switch cant come out of park
Old Sep 24, 2008 | 08:06 PM
rlevy64614's Avatar
Default brake safety switch cant come out of park
i went to buy a tank of gas in my 1998 ford taurus dohc six cyl car. when i started the car and put my foot on the brake to shift into d it would not move. it was stuck. i tried putting in neutral and putting the emer brake on and moving to a gear but it would not move. i tried a few times and then started moving the brake pedal to a few different levels. eventually it was ok and it has not done it since. altho it did it one time when i got home. wife now driving car and it seems fine. any insight. help. thank you
Old Sep 24, 2008 | 09:06 PM
Sterling_Six's Avatar
Default RE: brake safety switch cant come out of park
ORIGINAL: rlevy64614
I would advise to replace the Safety switch as so as possible...you may not be so lucky next time...it this goes bad...it goes bad real quick...
Old Sep 24, 2008 | 11:07 PM
rlevy64614's Avatar
turned out to be no brake lites. no brake lites at all causes this. ill let you know if its the brake switch or what tommorow thanks all.
Old Sep 25, 2008 | 05:51 PM
way2old's Avatar
The brake light bulbs will not cause the problem. The brake switch or the connection is more than likely the cause. Ford's connectors are a real weak spot.
Old Sep 25, 2008 | 09:13 PM
ORIGINAL: way2old
[&:]Agreed...this has to be the Brake switch causing this. This safety switch is designed to disallow the mechanism that allows you to place it into R...D..
So if some one is telling you this....they are so full of Cow Manure...lol
jimbokicksass
Feb 16, 2013 08:59 PM
Elayne
Aug 21, 2011 12:57 AM
homedepot
May 31, 2009 11:18 AM
lori5301
May 9, 2007 12:48 PM
