2000 zx2 tensioner pulley broke off at arm help
Old May 21, 2013 | 05:27 PM
billmik's Avatar
Default 2000 zx2 tensioner pulley broke off at arm help
Hello
Im in need of some help. On my 2000 zx2 the belt tensioner pulley broke off at 2 places. 1st was at a bolt hole on the pulley itself, The 2nd one concerns me, it broke off at a arm of some sort near the water pump. Can this be fixed? Where can i get the part?
Thanks
I attached a photo
Attached Thumbnails 2000 zx2 tensioner pulley broke off at arm help-img_0120.jpg
Old May 21, 2013 | 05:58 PM
Check with your local auto supply store. Give them your year,make , model,engine size , w/wo A/C, and ask if they have a belt tensioner assy in stock. Then go and see if it is the same as what you show in the pix. Usually easy to replace.
Old May 21, 2013 | 06:09 PM
billmik's Avatar
Default what about arm
Thanks for your reply, but what about the broken arm? where do i get it? the new tensioner will only have support for 1 bolt with out the arm. I attached a pic of the broken arm i took off the pulley
Attached Thumbnails 2000 zx2 tensioner pulley broke off at arm help-img_0123.jpg
Old May 21, 2013 | 07:52 PM
billmik's Avatar
Default ESCORT ZX2 2.0 L DOHC Water Pump Housing Power Steering Pump Bracket
After further looking i think i found the part. Can this be replaced? Have to pull engine? Any instructions please?
see photo
Attached Thumbnails 2000 zx2 tensioner pulley broke off at arm help-waterpump-housing.jpg
Old Nov 23, 2013 | 01:43 PM
Skahaguy's Avatar
Question Zx2 water pump housing
Exact same thing happened with my 2000 zx2. Tried jp weld to glue the arm, worked for a while then broke again. Did you get yours fixed?
Perry
Old Nov 24, 2013 | 09:02 AM
billmik's Avatar
Yes Got mine fixed. Had to change the water pump jacket (housing) The arm is part of it. Included pulling off the pullies and timing belt
Old Dec 31, 2013 | 02:29 PM
Skahaguy's Avatar
Thanks for getting back. Did you have to pull the engine to replace the housing?
Old Jan 1, 2014 | 11:32 AM
billmik's Avatar
No didnt have to pull engine. I just removed the 1 top mount next to the belt for more access and placed a floor jack under oil pan to help support engine. Here's the part on ebay Part #: F8CZ8505TG Got mine used for 45.00 .if your gonna do it make sure you get the F8RZ-8507-CA gasket and the O ring K31792 Water Pump Gasket http://www.ebay.com/itm/NEW-OEM-WATER-PUMP-HOUSING-TENSIONER-2000-3-FOCUS-1998-99-TRACER-1998-03-ESCORT-/231071323630?pt=Motors_Car_Truck_Parts_Accessories &hash=item35ccec95ee&vxp=mtr
creed2981
May 10, 2018 12:45 PM
Harqwyn
Jun 26, 2015 12:17 AM
FRESH x913x
Feb 9, 2011 08:22 PM
wildchildde1
Mar 31, 2009 12:29 PM
426Climber
Dec 30, 2006 06:36 AM
