94 Escort running rough
Old Dec 7, 2008 | 12:00 PM
tx4wheeler's Avatar
Default 94 Escort running rough
Hello,
I can't figure out why my 94, 1.9, AT, 150K Escort is running rough. It started by idling rough but running smooth after giving it gas. Now it misses through out the entire RPM range. Here is a list of things I have already done. Any help would be greatly appreciated.
New timing belt
New IAC Valve
New vacuum lines
New injector
New EGR Vacuum solenoid
New MAF
Different Computer
New coil pack
New plugs and wires
Compression test (between 125 and 150 on all cylinders)
Fuel pressure test (tested good)
New fuel filter
In a nut shell, It has good fuel pressure and good spark, but it is still missing. It does not have any check engine codes.
Thanks
Rob
Old Dec 8, 2008 | 08:58 PM
Sterling_Six's Avatar
Default RE: 94 Escort running rough
ORIGINAL: tx4wheeler
Hello,
New timing belt
New IAC Valve
New vacuum lines
New injector
New MAF
Different Computer
New coil pack
New plugs and wires
New fuel filter
Thanks
Rob
Hello and good day:
You may wish to check your camshaft sensor or crankshaft sensor first to see if it has voltage and reference.
This is what a Camshaft sensor looks like on your Escort:
The camshaft sensor is on the block,cam sensor is on head,toward front of car,back of engine (bell housing),behind exhaust manifold it depends what model engine.
goatsauce
Apr 15, 2013 08:32 PM
rrmojica
Dec 17, 2005 02:24 AM
fred_penner
Oct 28, 2005 02:41 PM
bundy351
May 6, 2005 03:21 PM
GiiDarwin
Aug 1, 2004 06:09 PM
