97 escort p1477 code
Old Apr 29, 2012 | 10:28 AM
krupa711's Avatar
Default 97 escort p1477 code
i have a 97 ford escort wagon and ive recently had the check engin light come on and the code is p1477. it runs and drives good. advanced auto said it was a clutch stuck code. can this be a easy fix? a solenoid? or possibly filter and fluid change? the filter a fluid wer changed last year before it sat for a year in a guys barn untill i bought it. and yesterday it was shifting very hard jerking me back into seat. can anyone help?
Old May 9, 2012 | 03:46 PM
bluewind's Avatar
Krash, that's no help!
Krupa: if you are lucky it may go away with "Lucas Oil Transmission Fix". It sounds like a valve is stuck and keeps the respective clutch from doing its job. If you are out of luck it may actually require an transmission overhaul. Such are the odds with automatic transmissions.
Disconnect the battery negative and step on the brake for 5 seconds to clear the trouble codes.
maineman
Aug 11, 2018 08:23 PM
cwildkats
Dec 27, 2012 09:59 AM
mar7
Nov 12, 2008 09:04 PM
jmg89
Nov 11, 2007 12:41 AM
nufan
Mar 27, 2007 04:17 PM
