99 Escort ZX2 temperature question
Old Mar 23, 2013 | 12:57 AM
Billy Bo Bob's Avatar
Default 99 Escort ZX2 temperature question
I finally have my 99 ZX2 roadworthy. I have a question about the temperature sensor. I notice that while driving, the dash gauge barely registers above the Cold line, even on 85 degree days. If I sit at a stoplight idling the gauge runs up almost to the middle between cold and hot. Once I start moving again it quickly drops back down near the cold line again. I have never seen a temperature gauge move so much so quickly.
Since I live in Arizona and summer is coming, I want to make sure my dash gauge is working correctly. Could I have a bad temp. sensor? Is there a way to check it?
Thanks all...for any input you give.
Old Mar 23, 2013 | 12:00 PM
grindman's Avatar
I know this might sound a little stupid but you might have a thermostat stuck open and the reason why your gauge is moving so much is the air flow going through the radiator. when your stopped at a light there ain't much if any going through it. Make sure that your fan works properly and then change the thermostat.
Old Mar 23, 2013 | 10:21 PM
bluewind's Avatar
I agree with grindman.
I would go ahead and flush the cooling system if it hasn't been done for a while. Time kills a cooling system because the electrochemical processes don't stop when you turn off the engine.
Also reverse flush the heater core. Some use a few squirts with a power washer to get the crud out of the heater core. Replace or at least test the existing t-stat. I fyou buy a new t-stat get a high quality part.
Old Mar 24, 2013 | 06:35 AM
Cooling system has all new fluids, hoses, thermostat, and fan motor. I'm not sure how to reverse flush the heater core. Could it be, or is it likely a faulty/flakey temperature sensor? OBD II scanner doesn't show any codes and when idling and gauge shows almost center with the needle, the scanner says it is running 214 degrees. I put a 180 degree thermostat in it since I live in the heat and thought it would be best to run more on the cool side.
I'll ask the mechanic when I get an estimate on fixing my AC. Thanks for the input.
Old Mar 24, 2013 | 09:03 AM
bluewind's Avatar
Since you have a completely overhauled cooling system I would not bother reverse flushing the heater core.
I am thinking your cooling system has an air pocket. Do this:
animal1408
Oct 2, 2011 09:30 AM
johnsonsnb
Dec 6, 2006 01:07 AM
Darkchild843
Jun 5, 2006 01:18 PM
waldoranger
Apr 8, 2006 02:49 PM
Kronos
Jul 13, 2005 07:04 PM
