Engine trouble
Old Apr 30, 2010 | 02:09 PM
terrymaher68's Avatar
Default Engine trouble
I have a 2000 Ford Escort, the other day as I was driving along the engine began to run weird, it sounds like it is choked up or running on only a couple of cylinders, if I put it in gear and try to drive it goes slowly, if I put it in neutral and rev the engine it sounds like it is all ok, but the minute I put it in drive and try to move thats when the problems begin. Any ideas as to what this could be?
Old May 19, 2010 | 05:49 PM
pashadowops's Avatar
My 97 had a similar problem. It turned out to be the coil pack. I cahnged the plugs and wires just for good measure but, be careful what wires you buy. I initially bought the Motorcraft OEM wires from Advance Auto and sucked big time. I went with a set of Accel 8mm wires and the car is running fine. Well I do need to replace the purge flow sensor and or the purge solanoid but, other than that it runs fine.
Old May 26, 2010 | 01:12 PM
Thank you, I did replace the spark plugs and wires and the same problem, I took it to a mechanic and it did turn out to be the coil pack, wish i had got this response before I took it but thanks for the reply anyway.
ksms124
Dec 17, 2009 06:12 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
mattballew
Nov 1, 2008 09:44 AM
hodge
Sep 5, 2008 06:04 AM
scortRus
Aug 26, 2005 02:52 AM
