Factory Specs on OK thickness on drum brakes?
Old Feb 5, 2007 | 07:27 PM
Aquakittie's Avatar
Default Factory Specs on OK thickness on drum brakes?
Would anyone know the factory specs for drum brake thickness? I need to replace some crappy shoes but we're not sure if the drum itself needs replacing as well. The rear brakes squeal and make a grinding noise when applying the brakeon a cold start. Also looking for a DIY on the replacement of drum brake shoes.
Old Feb 6, 2007 | 01:02 AM
Default RE: Factory Specs on OK thickness on drum brakes?
Standard....200mm (7.87inch)
Maximum inside diameter/service limit.... 201mm (7.91 inch)
coater
Jun 11, 2019 07:35 PM
techgrad03
May 9, 2012 08:18 PM
PitStop100
Jul 8, 2007 09:11 AM
fleetwd
Nov 1, 2006 12:14 PM
fleetwd
Nov 1, 2006 12:13 PM
