Flashing Battery Light
Old Dec 24, 2006 | 11:40 PM
seanny77's Avatar
Default Flashing Battery Light
Hello Everyone,
I have a 98 Escort. My battery light would come on and then a few minutes later it would go off. This happened for about a month. Now it stays on if the car is at idle and when i drive it flashes vigorously. Things that have been replaced
New battery as of 2 months ago.
Switched alternator about 2 months ago.
No calcium on the connectiors.
New connections-tight fit
getting 14.7ish volts from the alternator
getting 12.x volts from the battery
any ideas?
Should i get the alternator benched tested if it's giving 14.7 volts?
Old Dec 25, 2006 | 01:07 AM
wheelsup68's Avatar
Default RE: Flashing Battery Light
Sounds like an alternator problem again, but a quick ? first. Your battery voltage you haave already mentioned was 12.X is that with car running? do you have 14.7 volts at batttery or back of altenator post when vehicle is running. You might have a bad voltmeter in dash?
Old Dec 25, 2006 | 03:02 AM
seanny77's Avatar
yes 12.x from the battery when the car is running and 14.7 from the post while running. Do you still think it's the voltmeter in dash?
Old Dec 25, 2006 | 05:13 PM
wheelsup68's Avatar
There is definitely a problem witht he wiring somewhere. Most likely to be in the voltmeter in the dash.
Old Dec 25, 2006 | 10:25 PM
seanny77's Avatar
arg now i'm only getting 11.x volts from the alternator...i assume that would turn the battery light on?
edit..checked it again and it's at 14.7...weird.. any chance it could be the voltage regulator on the alt?
Old Dec 25, 2006 | 11:19 PM
seanny77's Avatar
a
Old Dec 26, 2006 | 04:39 PM
wheelsup68's Avatar
Altrernator would be the most probable problem, but its hard to make an accurate call with all the variables you keep throwing this way LMAO.
Old Dec 26, 2006 | 06:16 PM
seanny77's Avatar
lol i know...just got back from crappy tire and tested the alternator and it's good..tested the battery it's good...took off the wireing harness and inspected it...didn't find any problems with it...put it back together and it's fine now...time for a new winter beater!!!
lol sorry for all the variables they seem to change by the minute..fords...sigh.
Old Dec 26, 2006 | 10:48 PM
seanny77's Avatar
a
tomcat5
Aug 10, 2021 05:10 PM
guthrie1013@gmail.com
Jun 25, 2020 11:45 AM
irinadel
Jul 30, 2011 09:46 AM
ajrn
Apr 12, 2005 05:16 AM
