Idles great that's about it
Old May 18, 2008 | 10:39 AM
danddia's Avatar
Default Idles great that's about it
I have a 98 escort wagon 2.0 sohc. I have ran a compression check it is great so that leaves that valveout. I have changed my tps nothing has changed. It is hard starting but it will fire up and idles great and when you hit the throttle it boggs down. Could the timing belt skipped a tooth and know it out of time? Could somebody help.
Old Jun 1, 2008 | 07:36 PM
whiteescort1.9's Avatar
Default RE: Idles great that's about it
If it passed the compression test it more than likely isn't the timing belt skipping a tooth. I would check the Fuel filter and do a pressure test to make sure it is getting enough fuel as it sounds like it is not adding more fuel when you add more air.
Old Jun 2, 2008 | 09:27 PM
danddia's Avatar
It was a timing belt.
87Mojo
Jun 4, 2019 05:41 PM
CoreyTrevor
Oct 27, 2009 12:54 PM
tzh
Apr 23, 2008 10:04 PM
civshocker
May 26, 2005 12:02 PM
94Flare
Nov 30, 2004 02:50 AM
