water leak behind timing belt tensioner
Old Sep 24, 2006 | 03:23 PM
jec65's Avatar
Default water leak behind timing belt tensioner
water is leaking at the square hole behind timing belt tensioner, it is a 99 ford zx2 w/ a dohc motor. I don't have a clue why water is coming out of that area ? Any help would be nice. Thanks ...John
Old Aug 10, 2007 | 09:37 PM
EscortandFreestar's Avatar
Default RE: water leak behind timing belt tensioner
Sounds likethe water pump. How many miles??? The water pumpis usually driven by the timing belt.
Old Oct 20, 2019 | 08:33 AM
Bob Burton's Avatar
Default Water leak - Jon
Probably water pump, check if your fan pushes in and out or if it wiggles around in the bearing, or if you have noticed the tensioner being wobbles before the leak occurred.
jec65
May 10, 2018 12:14 PM
plawes
Jun 25, 2013 10:48 PM
dntcare
Jun 22, 2007 06:13 PM
AlphaMan
Nov 28, 2005 12:04 PM
skyfox
Aug 8, 2005 06:09 PM
