Excursion diesel with Manual Air/FUMES
Old Mar 2, 2005 | 02:55 PM
hauserc's Avatar
Default Excursion diesel with Manual Air/FUMES
Does anyone know if you can retrofit to the automatic air system from the manaul A/C system I have in my XLT diesel. With the manual mode air, you cannot use the heat in recirculation mode. You can only pull "fresh" air for heat. Unfortunately, when I do this the truck fills up with diesel fumes. My father in law has a Limited Excursion with the Automatic System. That system allows you to adjust air temperture in the recirculation mode. The manual system does not allow you to adjust air temperture in recirculation mode. Basically, you can only use air conditioning (at its coldest level) in recirc. mode. Please help! Its not safe more my child or pregnant wife to be inhaling diesal fumes.
Old Mar 2, 2005 | 10:18 PM
cctxfish's Avatar
Default RE: Excursion diesel with Manual Air/FUMES
hauserc,
I replied on the General tread, hope it helps
Old Jul 18, 2005 | 09:22 PM
Ramrod48's Avatar
Iam not really sure on the controller swap thing , But it shouldnt matter what you got , You shouldnt be getting fumes in the cab !!!!!, I would be taking it to the nearest dealer ASAP. Luckly Diesel fumes wont kill you like a gas motor will.. But it does an will make you very ILL , an possibly pass out .!!!!!!!!!!
2000EXP NC
Feb 11, 2008 03:00 PM
zoomy
Nov 27, 2007 04:19 PM
ozican
Oct 24, 2006 11:38 PM
mattlikeshockey
Dec 2, 2005 12:08 PM
hauserc
Mar 3, 2005 03:08 PM
