gear oil leak
Old Oct 17, 2010 | 10:28 AM
bp4606's Avatar
Default gear oil leak
have a 2001 excurision, has gear oil leaking out of the front axle tube, is this the outer seal causeing the problem or is there a inner seal closer to the ring gear and carrier unit, if so how much time will it take to repair
Old Nov 2, 2010 | 03:55 AM
It has an inner seal and it is quite involved to replace . Requires some special seal installer tools.
jcasaccio
Oct 7, 2018 08:02 AM
mtnman42
Oct 19, 2012 07:08 AM
Yapalot
Apr 26, 2011 05:29 PM
irvin63
Mar 12, 2011 06:14 PM
Aphotic
Nov 16, 2008 06:01 PM
