2007 Expedition cylinder 3 misfire
Old Dec 27, 2018 | 05:09 PM
Corey L Chaney Sr.'s Avatar
Default 2007 Expedition cylinder 3 misfire
I have changed spark plug and the coil pack what else would cause the misfire on cylinder 3
Old Dec 28, 2018 | 03:22 AM
It would help if we knew what you are working on. What engine?
Depending on what the misfire code is telling you, could involve fuel injector , signal to injector, signal to coil, possible valve spring problem. Best to have computer checked for any codes, places like Autozone will do this for you at no charge. Once we have the info , then can move in to narrow down the problem.
Old Dec 28, 2018 | 12:19 PM
It is a 5.4L engine misfire cylinder 0303
Old Dec 28, 2018 | 02:54 PM
If that is all you rec'd for codes, you are going to have to take the tourist route and that is :
check for spark at that particular cyl
make sure power is available to the coil for that cyl
Make sure the grounding signal for that coil is coming from the PCM
I believe that engine has "Coil on plug" ign syst. , quickie switch coils with a cyl easy to get coil from another cyl and see if misfire moves.
Listen/feel for the injector for that cyl to be operating.Make sure the plug on connections are good and snug
One of the last things to check would be to remove the pass side valve cover and check the valve springs for that cyl looking for a broken valve spring either on the intake or exhaust valves. Hope you installed Motorcraft plugs and the correct ones for that year and engine.
Sometimes a plug can get damaged on installation might try switching plug with another good cyl also.
F150-07-4.6
Aug 12, 2018 02:31 AM
djr32978
Mar 13, 2016 04:06 PM
Tuarus_2000
Jul 11, 2014 06:11 AM
deathrider2
Mar 21, 2013 07:23 PM
coll0211
Dec 23, 2010 03:48 PM
