2007 expedition Limited EL water in spark plug well
Old Jan 11, 2022 | 05:14 PM
Bcharrin's Avatar
Default 2007 expedition Limited EL water in spark plug well
Replaced plugs and coil packs because of several misfire codes. Ran fine for a few days then again misfire codes for cylinder 4. On inspection found water in the spark plug well. I think I had water in #3 and #4 when I changed the plugs and packs originally.
Old Jan 11, 2022 | 05:17 PM
scott.butler4's Avatar
Which engine do you have?
Did you use Ford plugs and coils? Fords do seem to run better with Ford parts.
Old Jan 12, 2022 | 03:33 AM
raski's Avatar
Some modular engines had issues with pressed in coolant pipes/ fittings leaking.. I am not sure your 5.4 is prone to those issues which would allow coolant to leak and collect in the plug wells but is worth looking in those areas for leaks. Water in the plug wells likely is causing the misfires.
Old Jan 12, 2022 | 06:16 AM
Coolant is what I'm thinking as well. The 5.4 heater hoses are known to leak on the rear of the bank 1 valve cover most the coolant ends up in spark plug holes 3 & 4.
If thats the case drain the coolant, remove BOTH the heater hoses, blow out the spark plug holes throughly and dry the coils out as well, reinstall coils, replace BOTH heater hoses and refill the cooling system.
daves2007
Oct 31, 2020 06:42 PM
Douglas Penning
Dec 8, 2019 02:40 AM
brimis
Feb 3, 2013 11:53 AM
ZR1Zoomer
Jan 22, 2011 06:10 AM
jtpilot1
Mar 20, 2010 08:37 PM
