2017 Expedition hard downshifting
Old Aug 6, 2020 | 11:50 AM
Spunky's Avatar
Default 2017 Expedition hard downshifting
I have a 2017 expedition. The issue is a hard downshift intermittently from 2nd gear to 1st. Ive had the truck to the dealership and they rebuilt the Valve Body. Didn't change a thing. Anyone have any other ideas what would cause this issue?
Thanks in advance!
Old Aug 10, 2020 | 06:33 AM
Would you know if they rebuilt the valve body or replaced it? Most dealerships are not equipped to do internal auto trans repairs.
Old Aug 10, 2020 | 07:10 AM
Spunky's Avatar
They claimed the rebuilt it.
Old Aug 10, 2020 | 09:42 AM
Did you inquire if you paid for a correction /repair and the problem was not corrected , what did the dealership service mgr say?
Would they replace the valve body this time?
Old Aug 13, 2020 | 07:50 PM
Spunky's Avatar
Repairs were covered under warranty. Still have to bring it back to the dealer. I have a 2 year extended warranty. So IhI plenty of time to bring it back. Trying to get an idea if the valve body wasn't the problem, what else could it be. I'd like to go back with some information regarding what may be causing this downshift issue. Thanks!
Old Aug 14, 2020 | 10:31 AM
It's good that you want to familiarize yourself with some aspects of automatic trans operation, however, you may find the more you learn, the more complicated a cause and solution can be.
Some service personnel don't take favorably to instructions from a customer who could be right or wrong , it doesn't matter, sometimes a problem exists there.
If it helps,
Something that could help could be providing as much information relating to circumstances present at the time the problem presents itself. Sometimes there exists a canned fix which can be used and other times a lot depends on the info provided by the customer. The problem with the vehicle most likely is not the first time they have come across it.
Sometimes they will attempt to correct it by using past experience and other times a more thorough procedure is required. Patience helps a lot at these times.
Samloveford
May 11, 2020 02:30 PM
Wbs181
Sep 18, 2018 10:10 PM
Wbs181
Sep 18, 2018 10:44 AM
meokey
Nov 24, 2017 02:52 PM
Al9
Dec 5, 2016 09:57 AM
