99 Expedition 5.4L Hard start
Old Oct 26, 2022 | 10:36 PM
pi3053's Avatar
Angry 99 Expedition 5.4L Hard start
After my expe sits overnight or for couple of hours its hard to start. I can turn key on and off multiple times then it will start. Any ideas as to problem.
Old Oct 27, 2022 | 02:05 AM
raski's Avatar
That does sound like an under performing fuel pump which is failing. You can confirm by measuring the fuel pressure at the service valve on the fuel rail. The pressure should be 30-45 psi at idle. By key cycling you are allowing the pump to build pressure towards the 30 psi level. A good pump should have built up sufficient pressure after one key cycle.
It would be a good idea to atleast replace your fuel filter first if it has been in service a while.
Old Oct 27, 2022 | 09:47 AM
raski's Avatar
Here is a picture of the tank module. As you can see, there is nothing outside of the pump other than tubing, the fuel level rheostat with float. The check valve is in the pump. I had a Ford module in my hands recently, there is no check valve external to the actual pump motor. If an OEM pump is desired for replacement, you have to buy the whole assembly module anyway.
https://www.rockauto.com/en/moreinfo...hO3Tl2DcQ9USI2
Old Oct 27, 2022 | 11:01 AM
Thank you for bringing that to my attention. I deleted the incorrect info.
bugy
Sep 5, 2012 04:12 PM
tazz603c
Jul 25, 2010 05:01 PM
rancherjosh
Jan 27, 2008 09:31 PM
wcjmmartin
Dec 16, 2007 09:01 PM
msd5052001
Jul 23, 2005 11:12 AM
