Air Conditioning Issue 2006 Expedition Eddie Bauer
Old Mar 14, 2021 | 03:11 PM
Doug Zaga's Avatar
Default Air Conditioning Issue 2006 Expedition Eddie Bauer
Hi,
I had my local mechanic replace my compressor, condenser and recharge the system. The compressor was replaced because it died. The vehicle has a front and rear system.
The rear system blows out cold air the front doesn't blow cold air. The system was charged according to specs for the dual system. I forget the specs.
We checked the blend door behind the glove box it opens and closes as per AC electronic controls require.
Anyone have an idea what we are missing and why I can't get cold air out of the front?
Thank you,
Doug Z
Old Mar 14, 2021 | 05:28 PM
Can you tell us if the lines going to the front evaporator are getting cold?
Old Mar 14, 2021 | 06:06 PM
Doug Zaga's Avatar
Hi Hanky,
Thank you for your response. If I remember correctly no the lines do not get cold.
Question when a compressor goes would the expansion valve get clogged and need to be replaced?
Would a bad expansion valve create the problem I have?
Doug
Old Mar 15, 2021 | 06:30 AM
Both questions get a ,,Yes !
Usually, depending on type of compressor failure, accumulator and exp valve, or orifice , get replaced.
Good practice is to flush the system and install an in line filter.
Old Mar 15, 2021 | 06:46 AM
Doug Zaga's Avatar
Thank you, Hanky. Have a great day.
Albertearl
May 3, 2020 05:35 PM
RH2OMAN
Nov 23, 2011 03:57 AM
sincity
Aug 16, 2010 07:22 AM
truetide
Oct 17, 2007 11:42 AM
gtam03@aol.com
Nov 20, 2006 12:24 PM
