Ford Expedition 2001 Battery Drain Fuse #15, #14, GEM
Old Apr 22, 2013 | 11:47 PM
expeditionph's Avatar
Default Ford Expedition 2001 Battery Drain Fuse #15, #14, GEM
I have a 2001 Ford Expedition, 4x2 4.6L
I have a Constant Parasitic Drain of .28 A, 280ma
I have followed the steps to the T in the ford service manuals.
Here is the case.
Test Scenario- Car off, all doors, hood everything closed, keys out of ignition
I tested all fuses and relays, with the series dc amp test.
1. When I pull Fuse #15,
(#15 = Stop Lamp Swith {Speed Control, Brake Shift interlock} GEM Module, RABS Module) 5 amp
It goes to .02a, 20ma
I put back Fuse #15
2. When i pull Fuse #14,
fuse 14 (Battery Saver Relay, Interior lamp relay)
It goes to .17a, 170ma
I put back Fuse #14
3. I pull the battery saver relay
I put new Battery Saver relay
Test again It goes to .17a, 170ma
* Did i close all doors hood and keep the multimeter connected YES
* did i wait 1 hour between test, including new battery saver YES
* New Battery Installed.
Tested Brake master cylinder CC deactivate switch by unplugging no change.
Tested Brake switch, removed connector no change in amps.
No Fuses are blown, all fuses are intact.
Things not working on Car.
Rear Wiper, - Ensured in seated position, pulled all fuses, disconnected motor everything related tested tested no drop in draw
Air bag light is on - only when key in ignition and started
Converted from Air suspension to Springs - master switch off under passenger dash, fuse pulled permanently.
Radio - cut memory wire just to be sure, went down 5ma only, not the issue
Cruise Control not work - ford dealer says its works and not code flashing, but it clearly does not work. I disconnected the deactivation switch on the master cylinder, no change in draw.. again pulled all fuses.. Cruse control never worked since i bought it 2 years ago.
Brake Switch - tested, by depressing brake, went up to 6 amps, all brake lights came on, shift lock working propery, after removing foot from brake went back to 280ma draw,,,Disconnect all brake swtich connectors, not change in draw..
Old Nov 14, 2016 | 07:23 PM
David Preston Jr.'s Avatar
Default I have exactly the same issue
Did you ever find out what was wrong with yours?
Captain B
11
Apr 26, 2023 01:07 PM
jalacia92
Feb 13, 2021 04:01 PM
Blondie1978
Jul 1, 2013 08:00 PM
ptc11952
Jan 25, 2012 07:26 PM
ATASTEVENS
Jun 25, 2007 05:07 PM
