Fuel Pump
Well the fuel tank is mounted under the drivers side inside the frame rail just in front of the real axle. There is a space just above where the fuel pump is located and I am not yet 100% sure if the fuel pump can be pulled out without lower the tank. I have raised the body a few inches and have the ring holding the unit in place loose so far. I will repost more information when I find out this evening just in case anyone else should run into this same issue.
Well yes the tank needs to be dropped. There are 3 straps to be released. Drop down the rear end of the tank with a floor jack or something and you can remove the pump. This should qualify to be on the "Dirty Jobs" show.
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
