Help me with part number!
Old Sep 16, 2022 | 03:40 PM
Lbenes18's Avatar
Default Help me with part number!
03 Ford Expedtion Eddie Bauer 5.4 L V8
Trying to find the part name and number for this combo vacuum hose. Has a boot with 3 hoses coming off it. Runs from back of intake to purge valve, another valve on top of drivers side fuel rail and to some other valve. Autozone could not locate in their system and I could not locate online. Hoping someone can assist as vehicle is stalling out when idling. Already replaced fuse box for fuel pump relay.
Old Sep 16, 2022 | 04:08 PM
Places that sell curb feelers room smellers are not going to have or carry what are considered :"Dealer Item parts"
Take your part to a dealership parts dept, if it can be had they can get it, they will need your VIN.
Old Sep 16, 2022 | 04:11 PM
Lbenes18's Avatar
A simple reply would have been nice. No need to be a smarta**. I was trying to order online
Old Sep 16, 2022 | 04:33 PM
I don't know of any other way to suggest other than to tell you like it is.
If it offended you , my apologies.
There are times when you cannot find many special parts on line and all I hoped to pass on to you was a solution to the problem.
In regard to a nice simple reply, The remark you made was not called for. A simple thank you I will give it some thought would have been more appropriate.
Old Sep 18, 2022 | 04:25 AM
raski's Avatar
You are not going to have much success getting any help here when you respond like that.
Old Sep 18, 2022 | 09:32 AM
And easy fix is..
You can take/reuse the rubber connector, remove the plastic lines. Then, insert small ribbed, barb type straight vacuum hose connectors where the plastics lines were installed. Then just run windshield washer type vacuum hose.
Old Sep 18, 2022 | 12:48 PM
Now why didn't I think of that, Thanks Hayapower.
LordCorpse
Jul 6, 2019 12:32 PM
ssilco2002
Mar 7, 2011 07:20 PM
Opaque
Oct 3, 2010 08:44 PM
tacamo
Dec 14, 2008 02:15 PM
kevcoz
Jun 19, 2008 06:20 AM
