No Dash heat/AC rear is working 99Exp
Old May 22, 2007 | 10:12 AM
Mike13579's Avatar
Default No Dash heat/AC rear is working 99Exp
I have a 99 Expedition XLT 5.4L and recently had only heat coming out of the dash when the AC was on. I have read every link to the blend door issues, and thought this was my problem. The next day it was cold in the morning, and thought I would at least have heat, but only very cold air came through the dash. Theback seat heat/AC work great and the fan control (blower) on the dash works fine.
I was under the impression that a faulty blend door in the dash would favor the heat or AC.......pending on which way it was stuck. Can this still be my problem still since both AC/Heat are not working? Is there a high voltage fuse that I could be overlooking?
Thanks
Mike
Old May 29, 2007 | 10:01 AM
Mike13579's Avatar
Default RE: No Dash heat/AC rear is working 99Exp
I found my answer, blend door is the problem.......thanks
ricknags
Apr 5, 2019 02:39 PM
cve
Mar 8, 2017 06:15 PM
Use Common Sense
Jun 25, 2016 01:30 PM
makuloco2000
Jul 26, 2014 05:23 PM
chp1959
Apr 21, 2009 12:22 PM
