Stuck in park
Old Dec 9, 2006 | 09:16 PM
squashbrain's Avatar
Default Stuck in park
My 1997 Expedition is stuck in park...The fuse for the brake light will blow as soon as it is replaced...I have replaced the brake switch...I have disassembled the dash to inspect the wiring between the fuse box and the brake light switch. The fuse still fries even is the connector is disconnected from the brake light switch.
If I disconnect the battery I can shift the transmission into neutral, start the vehicle and drive it. When I place it back into park it is there until I disconnect the battery.
Any help out there?
Old Dec 10, 2006 | 03:38 AM
Default RE: Stuck in park
Try unpluging the shift lock actuator on the lower column, replace the fuse and see if it still pops.. Brake pressure switch as well as their both on position #13 15amp.. Also, disconnect the cruise servo amp/module.. Few other things on that circuit but try these first..
Old Jan 9, 2007 | 01:26 PM
Vehicle is FIXED! Turned out to be a relay problem for the cruise control that Ford has a recall for. After the repair was done by Ford the problem went away. Had to unplug the the steering lock so I could drive it to the dealer.
Old Jan 9, 2007 | 02:55 PM
Should be this recall... But thats is/was the 'Brake Pressure Switch' for cruise deactivation that I was referring too in the previous post.. Glad they got it fixed...
SAFETY RECALL
05S28[/align]
Certain 1994-1996 Model Year Bronco, 1994-2002 F-150 through F-550, 1997-2002 Expedition, 1998-2002 Navigator, 2002 Blackwood,1994-1996 E-150/250/350, 1996-2002 E-450, 2000-2002 Excursion, and 1998 Explorer and Mountaineer vehicles equipped with Speed Control – Speed Control System Modification[/align]
August 28, 2006
TO:
All U.S. Ford and Lincoln Mercury Dealers
SUBJECT:
Safety Recall 05S28 - Supplement #9
REASON FOR SUPPLEMENT #9
The purpose of this supplement is to: [*]Announce new, more robust, electrical grease called "Electrical Grease II". This new electrical grease is to be used when performing Labor Operation 05S28E.[*]Update the technical instructions to direct technicians to use the Electrical Grease II.[*]Update the claiming instructions in Attachment I to reflect the cost of the new electrical grease.[*]Highlight unique Speed Control Deactivation Switch location and accessibility on E-450 applications.
[ul][/ul]
AFFECTED VEHICLES*
Year
Model*
1994-1996
Bronco
1994-2002
F-150 Through F-550
1997-2002
Expedition
1998-2002
Navigator
2002
Blackwood
1994-1996
E-150/250/350
1996-2002
E-450
2000-2002
Excursion
1998
[blockquote]
* Vehicles equipped with diesel engines are not affected.[/blockquote]
REASON FOR THIS RECALL
The underhood Speed Control Deactivation Switch (SCDS) may overheat, smoke, or burn, which could result in an underhood fire. The potential for a fire exists regardless of whether speed control is being used or the engine is running.
SERVICE ACTION
At no charge to the vehicle owner, dealers are to:[*]Disconnect Speed Control Deactivation Switch wiring harness connector and check the connector for presence of brake fluid contamination on all affected vehicles.[*]If the Speed Control Deactivation Switch electrical connector[/b]is not[/b]contaminated with brake fluid:[/b] Install the Fused Jumper Harness.[*]If the Speed Control Deactivation Switch electrical connector[/b] is[/b]contaminated with brake fluid:[/b] Using compressed shop air, blow dry the Speed Control Servo electrical connector and the speed control switch harness connector. Apply Electrical Grease II to the servo connector and to the speed control switch adapter jumper harness male pin connector. Install the Brake Repair Kit (Speed Control Deactivation Switch Kit).
[ul][/ul]
Repair Process For All Vehicles Involved in Recall 05S28
Old Sep 8, 2013 | 01:52 AM
bigblackbeauty's Avatar
Default 2011 Expedition XLT stuck in park
hi folks,
my 2011 XLT had an electric problem. Gear shift stucks in park position - blown fuse(breake light) has been replaced in that case - and it worked. So far so good - but this happened several times in the last 7 days and we run out of spare fuses.
My Ford dealer has replaced the electric connections within the trailer coupling after 5 days searching and billed over 500$. But yesterday it happened again. What i must say is, that the Expedition is very rare in germany and even Ford didn't sell it here(i imported this fancy car by myself). But has any one a suggestion, what i can tell the dealer/service team to find the cause?
It will be helpfull to get the wiring diagram for the shift lock solenoid or the brake switch.
regards from Germany...
Tone
Oct 5, 2014 11:51 AM
maxpower
Jun 24, 2013 08:58 PM
#1 backyard mechanic
Feb 9, 2009 01:30 PM
Giuseppe
Feb 28, 2008 10:01 PM
dstrwlt
Feb 1, 2006 08:21 PM
