transmission 4r100
Front pump flows lube to the cooler, from there it flows back into the pan via the return line. Lube is picked up in the pan and screened/filtered before it’s introduced into the unit/line systems. Is it still locked with OD canceled? Fine metal on the magnet, or suspended within the lube? What did the screen look like as far as debris?
