How much tranny fluid for c6
Old Dec 2, 2011 | 01:05 AM
sectlandscaping's Avatar
Default How much tranny fluid for c6
My pan is leaking and I'm going to pull it. I have to order the pan because nobody carries it. Going to replace the filter too. I just need to know how much fluid to buy? Also its a dump truck that I use for plowing should I get the deeper pan? If so how much more fluid would I need?
Old Dec 2, 2011 | 05:20 AM
Have you tried an auto trans repair shop ? They probably have some sitting around and answer all your questions .
Old Dec 2, 2011 | 11:35 AM
At the time it was leaking from both cooler lines. I had a quote for the pan and lines at $650. I did the lines for $35 in parts and two hours in labor. The pan is easier to do and cost maybe $80 in parts. So they were trying to rip me off.
Old Dec 2, 2011 | 12:16 PM
I believe you misunderstood my post or I should have stated the suggestion clearer.
What I meant was for you to ask the shops for an old trans pan from a C6 since they probably have scrapped cases lying around. Whatever you would have paid for the pan might have included the answers to your questions.
In either case, I'm glad you were able to correct the leaks and changing the pan is pretty cut and dried. We generally do not use any kind of sealer or adhesive on the pan gasket just be careful and don't over tighten the pan bolts. Have a good day!.
Old Dec 2, 2011 | 09:09 PM
Gary2Wheels's Avatar
I think a total fluid change (torque converter included) will put you up around 13 qts..mebbe a pint more or less depending on how much old fluid you can drain out of both the transmission and converter....
Old Dec 3, 2011 | 04:43 PM
S Rammer's Avatar
I picked up a 95 f250 4x4 7.3 diesel and am not sure what tranny is in it or if it's comparable with other ford motors
Old Dec 3, 2011 | 07:36 PM
It most likely is an E4OD trans. There were several bolt patterns available. Check carefully should be able to find one that will mate.
Old Dec 4, 2011 | 09:02 AM
A simple way is to see if 'OD' is indicated on the shift indicator...if so with the 7.3,you'll have the E4OD transmission...it's also stamped 'E4OD' on the bottom of the transmission oil pan
low96hb
Oct 20, 2008 06:06 AM
SAMF
Jan 14, 2008 11:58 AM
87broncoll
Dec 18, 2006 08:02 AM
T Mo 93 Explorer 4x4
Nov 6, 2006 12:58 AM
vaman4215
Apr 23, 2006 02:52 PM
