03 Exp XLT 4.0 AC compressor bypass
Old Jan 21, 2014 | 02:41 PM
jwc.enterprise's Avatar
Default 03 Exp XLT 4.0 AC compressor bypass
My compressor literally exploded. Two lower mounting bolts have been removed, upper bolt snapped off in recessed bolt hole. Making it impossible, for me (the amateur) to access it. My question is this, can I bypass the a/c with a shorter serpentine belt... without affecting proper motor function? At this time, I cannot afford the 14-1500 to have the system fixed.
edit: The stock serpentine belt is 85.5" in length, I used a belt 71.5" to bypass a/c compressor. $21 and I'm back in business! Until I get my funds
together for the "correct" repair. I hope this helps.
Old Aug 30, 2018 | 10:52 PM
03 expl 4.0's Avatar
Default A thank you.
Created an account just to personally thank you. The length was perfect and was up and running in no time. Considering how expensive a new compressor is this saves me so much money. My belt snapped after the compressor seized and car over heated momentarily, but after pulling into a mall parking lot and walking to a parts store for your belt size, I was right as rain. Thanks again.
Old Aug 31, 2018 | 10:27 AM
With any compressor bypass, you loose the de-humidify portion of the defrost function.. Heated air for the defrost won’t have moisture removed without an AC compressor run in defrost modes.
Old Feb 3, 2020 | 01:42 PM
Bridget Kay Wortham's Avatar
Default 2003 Ford explorer XLT compressor locked up
Hello I was curious if your explorer was a 2003 4.0 xlt like mine I'm having the same issue with mine as well and funds aren't good right now was curious if this is the right size belt
bowlermike
Feb 5, 2017 12:57 PM
trailbreaker
Jul 22, 2016 11:07 PM
mrthat
Jan 12, 2012 11:53 AM
kfederig
Oct 17, 2009 10:47 AM
kmsalcido
Mar 8, 2007 01:43 PM
