1993 Explorer Dying
Old Oct 10, 2006 | 12:11 AM
vhillers's Avatar
Default 1993 Explorer Dying
Hey guys, long time lurker, first time poster. Well I have a 1993 Explorer with the 4.0 motor in it. A few months back it started having problems with surging and then dying while going down the road. So I read the message boards and since my sending unit for the fuel gauge went out, I decided to replace the fuel pump. When we got it back together Saturday it ran like a new explorer, no surging, dying and me no cussing. Well we drove it about 200 miles with no problems and I got in it this morning and the problem started all over again. I went and replaced the fuel filter and fuel regulator. So i went for a drive again and it drove great, but when i got back in it to come home it did its thing again. I then went and replaced the air temp sensor, MAF, and new plugs and wires When I hold the gas pedal to the floor it doesnt immediatly die, it bogs way down, like sucking more air than anything, then dies. I'm stumped.. Last things that i could replace would be the TPS and o2 sensors. When i come to a red light it idles funny like it wants to die but doesnt. And when i give it gas when it want to die it make this real bad knocking sound. Thanks in advance
Old Oct 10, 2006 | 12:27 AM
94 4x4 ranger's Avatar
Default RE: 1993 Explorer Dying
[sm=welcomesign.gif][hr]Try to swap the fuel pump relay with the a/c relay in the power distrubtion box under the hood these fuel pump relay's go bad.
Old Oct 10, 2006 | 01:27 AM
vhillers's Avatar
If the relay was bad wouldnt the pump not work? Or would it just be intermitent?
Old Oct 10, 2006 | 01:39 AM
It could be intermitent.[hr]Somtimes the electrical contacts go bad and will not allow full current.
Old Oct 10, 2006 | 01:41 AM
vhillers's Avatar
ok thanks, ill try that. be back in a few
Old Oct 10, 2006 | 01:53 AM
vhillers's Avatar
Ok same problem even after changing the relay. If I unplugged the IAC should or shouldnt it idle funny? And i also unplugged the TPS and it had no change on the motor.
Old Oct 10, 2006 | 01:57 AM
If any of the sensors were bad the check engine light would be on .[hr]Is the check engine light on?
Old Oct 10, 2006 | 02:04 AM
vhillers's Avatar
It does come on. Sorry i didnt mention that. The night we drove it around no CEL came on. Today it came on, i had taken it to Auto Zone to get a tester put on it, they said it was my MAF, Air Temp Sensor and o2 sensors. I replaced the first 2 but called a shop about the o2's, they said that if the o2 sensors were messed up that it would act up almost immediatly. Im stumped on this one
Old Oct 10, 2006 | 02:09 AM
That may be it then.[hr]If the computer is telling you the part is bad it usally is.[hr]I would replace the o2's and see what happens.
Old Oct 10, 2006 | 02:15 AM
vhillers's Avatar
Thanks, im going to replace them this week and see if i stop cussing or not, ill get back with ya on it.
ford sf ranger
Jan 13, 2007 09:42 PM
lauk101
Jan 12, 2007 02:51 PM
pollok22
Dec 6, 2006 11:14 PM
Renz01Expo
Aug 15, 2006 08:07 PM
FERNDOG
Dec 26, 2005 04:58 AM
