98 explorer a/c issues.......
Old Jul 4, 2008 | 08:35 PM
thtanoyinguy's Avatar
Default 98 explorer a/c issues.......
my mom has a 1998 ford explorer sport with the sohc engine and last year the a/c went out so i dye checked it and found the accumulator leaking behind the insulation on it. So, i replaced it and recharged the system and never had another issue...til now... within the last month it has developed a problem were the cold air comes and goes. the blower never stops but one minute the air will be freezing and the next it'll be hot. sometimes if you crack the windows it'll get cold again and sometimes when you turn the a/c off and count to 10 and turn it back on it will cool again. so i checked and it is full of freon, so i was figuring a freeze up so i replace the low side switch on the accumulator but it didn't fix it. i was your basic straight out of college mechanic for four years, but i was never good at a/c work and most dealerships and shops i worked at wouldn't allow me to work on a/c without taking their class. so please help me....thanks
Old Jul 9, 2008 | 02:39 PM
btexpress's Avatar
Default RE: 98 explorer a/c issues.......
You should check the blend door operation. This vehicle is common for blend door breakage and blend door motor failures
dwarber
May 4, 2025 11:31 AM
Allnbrgdn
Oct 11, 2006 02:21 PM
pkrfan1
Aug 11, 2005 01:42 PM
tboy83
Mar 22, 2005 01:24 PM
