98 Explorer crankshaft position sensor
Old Sep 4, 2017 | 09:18 PM
Explorher69$'s Avatar
Default 98 Explorer crankshaft position sensor
I have a 98 explorer xlt, with the 5.0 engine,I recently bought it and the engine light was on,I hooked my OBD reader up and the code was P0340,crankshaft position sensor, had anyone changed this and can give me the steps to change it or have any videos on how to change it. ...ty
Old Sep 5, 2017 | 06:01 AM
You might want to recheck the fault code for your particular vehicle , it might be for the cam position sensor that is located on the top back of the engine where a distributor used to be.
You might also type in, 98 ford explorer cam position sensor replacement.
Shows videos and procedure.
Old Sep 5, 2017 | 11:45 AM
The code said crankshaft/camshaft sensor, I was watching how to test the crankshaft and they said your vehicle would not start if crankshaft sensor was bad but mine still running,I will check the camshaft sensor,thank you
krein
Jun 27, 2009 02:59 PM
rgharris417
Nov 26, 2007 05:56 PM
rgharris417
Nov 25, 2007 03:52 PM
Candie27
Mar 28, 2007 03:56 PM
justin1980
May 30, 2005 10:28 AM
