98 explorer transmission
Old Nov 11, 2007 | 12:40 PM
cral's Avatar
Default 98 explorer transmission
ok here it is
THE PROBLEM:
it wont go into reverse and in drive it goes fine in 1st and 2nd gear but the higher ones tend to rev more then actually work.. The over drive light keeps blinking on and off.
ENGINE:
4.0 SOHC 4x4 XLT
any solutions would greatly be appreciated.
Old Jan 1, 2008 | 11:15 AM
cral's Avatar
Default RE: 98 explorer transmission
so i took it to a transmission shop and the results were as follows;
all the gears were good
problems was :
the heat temp sensor inside burned up causing the traning to over heat which lead to all the acuators and other internal sensors to burn out thus causing the training from working properly.
he said this was rare and the cause of this failure in the transmission is usually the planetary gears breaking which was not the case in my situation.
Gaston
Jul 31, 2008 11:32 AM
sam66
Nov 9, 2006 09:45 PM
pkrfan1
Aug 11, 2005 01:42 PM
