98 UP - ABS fault light - way to read the error codes?
I have a 1998 Ford UP Explorer XT. The ABS fault light is illuminated on the dash. Anyone know how I can read the fault codes? I assume there is a method as the Australian built Ford Falcons of similar era have this capability.
I have tried replacing the ABS sensor on the rear diff (I was told this is a common fault as it fails), and that did not help.
The ABS fault light often illuminates after I have launched my boat in salt water. Unit recently when it has continued to stay illuminated.
