99 Explorer starts, but no idle
Old Aug 24, 2007 | 02:50 PM
jnorback's Avatar
Default 99 Explorer starts, but no idle
My -99 Explorer V6 4.0L SOHC starts if I give some gas and keeps running, provided I keep giving gas. But as soon as I let go off the pedal, the engine dies. Clean as if I would have turned the ignition off.
I've checked the IAC and the TPS and the values are spot on according to the Haynes manual.
There is a hissing sound that is fluctuating a bit with the rpm and fades away once the engine stops.
Any ideas, please? You guys wouldn't believe the workshop prices here in Sweden for such a car.
Old Sep 4, 2007 | 12:56 PM
jmb392003's Avatar
Default RE: 99 Explorer starts, but no idle
I had a same problem with my 2000. I had the replace the manifold gaskets which solved the problem and started and idled no problem
Old Sep 6, 2007 | 01:57 PM
jnorback's Avatar
Thanks,
I took the opportunity to replace the cam chain tensioners (before it starts to rattle). As part of that process, the manifold is off and I replaced the gaskets. They were indeed dried out and well overdue. Unfortunately, the idle problem remains although there is now an effort to stay alive. Maybe there is a crack in the manifold somewhere.
Maybe it's time to bring in the pro's after all. [:@]
Old Oct 2, 2007 | 05:52 PM
broknpiston's Avatar
G`day friend
Just brought a 1999 explorer with what sounds more like noisy lifters
do you know if they suffer froms this or is it tensioners ?
What sort of cost would i looking at ?
Cheers
Roger
Old Oct 2, 2007 | 09:09 PM
Mulletman's Avatar
The noisy lifters is probably the timing chain tensioners.
jnorback sounds like he has an intake leaking or a vacuum line or PCV line is leaking. Listen real close for the hissing sound and you will find it.
goatsauce
Apr 15, 2013 08:32 PM
snapper1d
Dec 10, 2010 09:26 AM
streetglide007
Apr 11, 2010 12:23 PM
onelap
Oct 22, 2007 10:08 PM
oneproblem
Jul 9, 2005 03:31 PM
