Alternator Not Charging 2011+ Here's Why
Old Mar 27, 2014 | 09:24 PM
makuloco2000's Avatar
Default Alternator Not Charging 2011+ Here's Why
Just wanted to pass this info along as some may be experiencing perceived weak batteries or just want to do the occasional checkup before a long road trip and bam you find the alternator is not charging, don't worry just yet here is why....
Old Mar 28, 2014 | 10:54 AM
Thanks for the informative video.
Old Mar 29, 2014 | 07:24 AM
If the vehicle battery is replaced, carry out the Battery Monitoring System Reset using the scan tool. If the Battery Monitoring System Reset is not carried out, measurement data collected for the old battery is not deleted and future state of charge measurements will be inaccurate. For example, if an old battery has a state of charge of 60% and the new battery has a state of charge of 90%, the BCM will recognize battery state of charge being 30% lower than it actually is. With the battery state of charge being perceived lower than it actually is causes shedding of loads earlier than is necessary. This also impacts the smart regenerative charge system by causing the battery to be maintained at a higher state of charge than perceived by the BCM, reducing fuel economy benefits.
Old Mar 29, 2014 | 08:57 AM
Here is the original Alternator Load Testing video that I refer to that is still the most accurate test even on these new charging systems.
cardiag12
May 16, 2011 03:01 PM
awwphooey
Jul 26, 2010 02:47 PM
lisam
Apr 20, 2009 01:41 AM
djporche
Mar 12, 2009 11:09 AM
