Bank 2 too lean
I have an '03 Explorer with a check engine light on. The code says "Bank 2 too lean" The vehicle runs fine in town, but on the highway, going up hills and when I pass, the engine downshifts fine but the speed does not increase. Also in this case, the engine pings. I would only get about 12 mpg on the highway.
I checked everything for vacuum leaks and found none. One shop said I had a bad Catalytic converter which I doubt. Another shop said the cat is good, but it needs a new O2 sensor before the cat.
Wondering if anyone has had similar problems
Jay
Jay
My understanding with the newer models (I just have old stuff!) is that if you had a vacuum leak you'd get a lean indication on both banks (code P0171 an P0174 as I recall). I've read somewhere you can test O2 sensors, but I haven't actually done it. You might be able to search the forum or the internet on procedure.
nicktodisco
Aug 25, 2010 06:43 PM
JohnnyG-f150
Aug 10, 2010 10:27 AM
bandit1
Jan 2, 2007 10:00 PM
