C1155 code
Old Oct 7, 2018 | 10:58 AM
Durfey21's Avatar
Default C1155 code
I have a 2010 Ford Explorer Eddie Bauer Edition. I had the fault code C1123 for my left front wheel speed sensor. I replaced the wheel speed sensor with a BWD sensor from my local parts store. And that code went inactive but now I have a fault code C1155 can anyone help by telling me what could cause this new fault code. Because my SUV is telling me to service the RSC but the only fault I had was for my wheel speed sensor. I’m lost with this thing.
Old Mar 13, 2020 | 12:03 PM
cngizbleevng's Avatar
I've had ongoing problems with my left wheel speed sensor too. Replaced it a couple months ago, and now today C1155 came up. I'd like to know what this is about too.
Old Mar 13, 2020 | 02:01 PM
Something you might be overlooking,
Some manufacturer specific codes attempt to narrow down a problem with a particular system. Unfortunately replacing a sensor is not always the correction.
Wiring problems can also be present. Some sensors send what we call a bias voltage down to the sensor when you first turn the key on. that step will check some of the integrity of the circuit and if a fault is found the light comes on as soon as the vehicle starts moving. If you replaced the sensor and everything was installed correctly, the 1155 code is telling you something is not complete with the circuit/system. The object now is to chase down the wiring and connections until the cause is determined.
bobbytowery
Feb 6, 2026 06:50 PM
Franklin Cognito
May 4, 2012 10:47 AM
915exp ford
Sep 19, 2009 01:31 PM
rlevy64614
Oct 15, 2007 12:40 PM
rlevy64614
Aug 14, 2007 11:26 AM
