check engine light
Old Dec 19, 2006 | 07:35 PM
bigtim's Avatar
Default check engine light
How do you reset the check engine light?
Old Dec 19, 2006 | 10:14 PM
Malibu Barbie's Avatar
Default RE: check engine light
The lightshould go out if you disconnect and reconnect the battery. This clears the error code stored in the computer. Please keep in mind that the Check Engine Light will come back on if you haven't repaired or replaced the part that's causing the error.
Old Dec 28, 2006 | 03:45 PM
sjwoody's Avatar
Yes, and I'd leave the battery disconnected for several minutes. If the problem has been fixed, the light should remain off. I understand the vehicle needs to be drivenfor several miles so the computer can re-learn various parameters, and the vehicle may run sluggish during this time. If your truck is a 95 or newer, disconnecting the battery won't help...at least it didn't on my Caravan.You need to have the light cleared by an OBD II scan tool or code reader. There's always exceptions though...I don't remember the number of "drive cycles" (start-up, warm-up, speed, shut-down...40 comes to mind) but if you fix the fault, the light will clear by itself after the correct number of drive cycles have been accomplished.
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
