Crank but won’t start
Old May 30, 2018 | 12:52 PM
Jordan Anderson's Avatar
Default Crank but won’t start
I have a 2004 Ford Explorer Eddie Bauer V8. One day while driving the vehicle lost engine power and eventually stopped. I got the vehicle back to my house and diagnosed that the fuel pump was faulty. I have replaced the fuel pump and fuel filter, however now the vehicle does not start at all. I have checked the fuel lines, the injectors, the spark plugs, and the fuel pressure sensor to find the are all in good working order. A strange thing I’ve noticed it that when I allow the car to sit(roughly a day or two) the fuel pressure seems to build up enough to where the engine almost fires. I have yet to test the fuel pressure being as I don’t know which location to hook into. Any assistance would be much appreciated.
Old Jun 3, 2018 | 12:18 PM
Welcome to the site..
Full pressure/volume should be verified. Return type systems will have a shrader valve on the fuel rail topside of the engine..
Old Jun 8, 2018 | 12:33 PM
Would the engine need to be running to get an accurate reading or should I just check what the current pressure is?
Old Jun 9, 2018 | 12:32 AM
Key On/engine Off is the same for a running engine.. 30-40 PSI
When the key is cycled On, it should build that pressure value quickly...
flyboyz
Jul 12, 2019 09:26 PM
wheref15sdare@gmail.com
Jul 1, 2019 04:53 PM
saemetric
Jul 23, 2015 01:41 PM
30ford
Aug 22, 2011 08:40 AM
digby
Mar 19, 2009 04:08 PM
