disengaging transmission help
Old Sep 21, 2007 | 06:08 PM
pid's Avatar
pid
Default disengaging transmission help
drives good shifts good but let off the gas say at 60 and
it disengages and makes a noise like you put it in reverse going forword put it in N rev it up and back in D and it is ok till you let off the gas again 117,000 miles please help
Old Sep 22, 2007 | 12:55 PM
rdnnhra's Avatar
Default RE: disengaging transmission help
Same type of thing happened to my explorer when it had 150,000 miles. Found out that the overdrive clutch pack is in the same housing as the reverse clutch pack. The plates and discs were worn out and I had to have the transmission replaced. Check your oil to see if it looks burnt and it may smell foul. The costof repair will vary from 1500.00 to 1800.00 depending on the shop. I am sure this wasn't the reply you wanted. God luck.
Old Oct 16, 2007 | 07:37 AM
pid's Avatar
pid
it was the transfer case if any one else have this happen
Old Nov 23, 2007 | 06:55 PM
djmassi's Avatar
I have to have a transfer case replaced myself, but for a different reason. It shifts fine into gear but then won't go anywhere as it just dies as soon as you hit the gas.
How much did the replacement cost???
Massi
aalex4109
Nov 6, 2010 03:52 PM
adam10
Mar 23, 2010 10:39 AM
Adrian1981
Nov 26, 2006 09:54 PM
