Explorer 2005 Headlight adjuster beam
Old May 1, 2023 | 12:13 AM
MrBuddaBong's Avatar
Question Explorer 2005 Headlight adjuster beam
Hello again my fellow Explorers. Can someone help me out with the proper way of adjusting my headlight beam. I was out tonight trying to figure what is going on with my headlights. They seem to be abit high. They are hitting the signs along the road. I've been inspecting the beam adjuster part. However, I was moving it side to side. And for some strange reason nothing really happens. Its sort of loose and just in place within the headlight brackets behind. Is the broken or needs some sort of tighten ? Anyone else tried adjusting these properly? Any help would be appreciated.
Old May 1, 2023 | 04:09 PM
raski's Avatar
I would have a body shop do it for you.They know the procedure where the beams land at a given distance. . It's more than tweeking adjusting screws and guessing that it is correct and won't blind oncoming traffic.
Old May 2, 2023 | 10:44 AM
Most headlamp assys have an adjustment for horizontal AND vertical positioning. Did you look for the second adjustment.
Old May 4, 2023 | 12:25 PM
Hanky. all I see is a vertical beam that moves side to side. It doesn't do anything to adjust the beam. I see nothing else to adjust behind the headlight.
Old May 4, 2023 | 12:27 PM
Okay raski. Would they do some modifications ? Like fabrication.
Old May 4, 2023 | 07:12 PM
A little tip,,,many times a lamp assy will kinda freeze there . When turning the adjustment screw a little in one direction you might carefully bump the lamp with your hand to dislodge it and watch which way it moved. Now you have an idea which way you want to go You may need to bump the front of the lamp to get it to move each time
Old May 5, 2023 | 12:26 PM
Default Explain more
Hanky, Can you explain a little more in detail ? I tried bumping and adjusting the headlight position. But no luck with that.
Old May 5, 2023 | 12:45 PM
Are these the original bulbs in your lamps?
Old May 5, 2023 | 02:21 PM
Default Not original bulbs
Hello Hanky , no the original burnt out years ago. I have other bulbs same size.
Old May 5, 2023 | 03:48 PM
On some units, you would loosen the adjustment screw move the headlamp where you wanted to have it shine , then tighten the screw.
See if that works for you.
firstfordguy
Jan 22, 2023 05:19 PM
TMock
Nov 1, 2021 06:20 PM
hfb1957
May 17, 2010 10:29 AM
FE150VAN
Sep 16, 2007 04:35 PM
STEVE1103
Apr 14, 2007 10:01 AM
