Heater/AC fan randomly working/not working
First time posting anything anywhere, so you know I am desperate.
The heater/AC fan on my 1999 Explorer 4 dr. Limited (V6, auto, 2WD) runs sometimes, then sometimes not. It had the common resistor (only runs on high) problem about a year ago,so I replaced it and that fixed that problem. Now it has decided to simply work randomly. It may be my imagination, but it seems to come on when you run over a bump or slam the hood. I changed the fan relay and it worked for a fewhours (tease!) then went back to its old ways.
It seems as though it is a loose ground, as a pot hole will sometimes jar it to work, once working, it stays working until I turn off the engine. But all looks tight and checks out. No squealing, no bearing noise. Could the fan motor have a "burned spot(s)" on the commutator, could it be that this is a Lucas Electricfan somehow installed when Ford bought Jaguar? at least then (as along time British Car Owner)it would make sense.
I know that I can't be the only one with this problem, but I looked at the Forum and most address the resistor when the fan "only runs at one speed" solution. That's not my problem, mine is one of a fan with a mind of it's own.
I have no problem replacing the fan motor, but don't want to start on the slippery slope of replacing parts at random hoping for a cure, although that's how you have to appease British Cars. It's not about the parts to them. They just have needs... Thanks, Andy
[IMG]local://upfiles/14697/D27351AE38D448269D2D4520CD717870.jpg[/IMG]
[img]local://upfiles/14697/D27351AE38D448269D2D4520CD717870.jpg[/img]
The only thing left to check and"Replace" is the blower motor switch itself. There maybe a little work involved to get the switch out, but if the motor was getting tired it would have placed a current load on the switch and plug contacts.
Taking the path of just replacing things can get expensive and disappointing.
