Heater does not blow out of vents
Old Jan 8, 2022 | 09:01 AM
rickli's Avatar
Default Heater does not blow out of vents
Hello,
My 1995 Explorer's Heater does not blow out of vents occasionally. Only out of front defroster?
blows out of front defroster?
Old Jan 8, 2022 | 11:23 AM
raski's Avatar
You have a vacuum leak. Car engineers design the system to "default" to defrost with the absence of vacuum supplying the heating and a/c controls and blend doors. A likely place to look is under the hood at the vacuum resevour or the line attached to it. It will either resemble a large tin can, plastic ball or a plastic cannister mounted on the fender well in the engine compartment.It is common for these resevours to leak or vacuum lines leaking.
Old Jan 8, 2022 | 02:10 PM
rickli's Avatar
Originally Posted by rickli
Hello,
That is great advise- thank you.
Purplekangaroo1
Nov 12, 2012 01:49 PM
tiko23
Nov 4, 2011 09:31 AM
totallyick
Feb 23, 2008 09:37 AM
daveranger
Dec 24, 2006 01:01 PM
ericftz
Sep 3, 2005 09:02 PM
